40mm Solex Carbs
I have a pair of 40mm Solex Carbs from one of the Industrial engines Heritage were selling last year. These engines apparently have only been bench run so have very little wear. The condition of the carbs support this. The carb bodies themselves are a little grotty but otherwise they are like new with the original grease on the linkages etc. I have a pair on the engine in my Bay and they promise to be fantastic. The carbs come with the manifolds and linkage bar. I will also provide the airbox.
The linkage needs to be modified to align the armature with the hole that the accelerator cable comes through. A couple of welds does the trick.
I will take a few pictures tomorrow.
For all of the above a mere £250.
