Bay camper parts, 1700 type 4 engine, weber twin 40 IDF carbs for sale
More clearing out!
Dual twin Weber 40 IDF carbs - complete with air filters and linkage as removed from my bay 5yrs ago.
Genuine Webers made in Spain and not empi copies!
They are as new and have no more than 5k on them. Ran on 1600cc perfectly and accelerated up shap heading north at 70 with more to go!!!
£400 ono quick sale. cost around 650 now!
2 x RHD bay slider, factory window type, both have had inner and outer lower panels replaced but require filler work to finish. One has glass with as new rubber still fitted. £100 each
Various early & late bay cab doors - couple would do if none at all, others are repaired and require final filling or slight welding - ask for prices
3 x bay Tailgate - solid, minimal fillering required to finish £20 each
1700 type 4 engine CA code for bay van. Stripped down to long block - suspect needs one or new barrels and pistons to be A1 as compression was low/burning oil. All tinware and good pricey heat exchangers/heat pipes, alternator, flywheel etc present. No time to rebuild. Good power compared to standard 1600! £350
Twin choke weber carb and manifold to fit above engine or any 1700-2L type 4 motor £100
1600 late bay gearbox - good condition, was in one of our hire campers that was written off and poss one of the best ive had hence why ive kept hold of it. No grinding or whining! £175
3 x Devon louvre window £20 each
4x wide 5 hubcaps with VW logo. As new but been in shed for couple of years and one has slight scab. Other than that new looking and shiny and would do a year or two! £20
T25 offside rear factory sliding window £20
Just Kampers traditional shape ( square ) blue awning with integral smaller tent. Bought new 2007 and used once at Vanfest. Was 200 … £100
65 & 66 beetle engine lids ( long style ) good condition and complete with number plate light, £40 each
Possibly a good recon 1584cc van engine for sale that i have kept as a spare for wedding cars - i have a new boxed 1641 kit that i can fit and good heads as i used the previous ones on another hire van.
Please ask for price built up complete and running, compression tested, tuned or built up for you to see it running then stripped back to long block and fit your own parts, exhaust etc.
Various other spares for bays and beetles that im tripping over - trying to compile a list asap but please ask now if you need anything - i possibly have it.
Cheers folks!
