Hello, is there anybody got a lock mechanism for a drivers door on a bay, it’s the type without the pull up and down button. It locks inside with a lever next to the main latch.
Cheers.
Cheers.
The (pattern part) handle+lock mechanism is only £14 from JustKampers, if you can’t get a second hand one.
Cheers Graham,
I had a wee look but could only see handles, you wouldn’t know the part number per chance? The JK site has changed recently and seems a bit harder to find your way around (for me).
Ah; it’s the handle assembly ( http://www.justkampers.com/shop/type_2_bay/type-2-bay-original-vehicle-parts/body-panels/handles-locks/cab-door-handle-including-2-keys.html ) that I’m talking about - since that’s what the key goes into. (And which is what I’ve replaced on two different vehicles now - why do POs always lose the key for the passenger door?!) But I don’t know about any other lock type bits I’m afraid.
Thanks Graham, it was the bits inside the door I was after. I contacted Volks Heaven and they are meant to be sending me a replacement tomorrow…
I never have any luck ordering stuff, if there is a differen’t or wrong part I usually end up with it!
