I’m beginning to think I am, when I picked the T4 up the alternator had packed in unknown to me & I had to get a tow home. No probs, changed it once I got back n all’s swell, it also seemed to be loosing coolant, I picked up a spare radiator tried to fit it… wrong size!!! went to swap the radiator the other night with one I thought would fit (after trying it yesterday it’s again just to big) but on the way to pick it up something wierd happened n the electrics went funny. The electrics where sorted the same night thanks to the club member helping out. Coming home this afternoon I went to change gear & nadda nothing, it was like someone had welded the gear lever in place, I could get it into 4th, if I shoved hard enough it would go into second & if I pressed down & went for reverse I could just get it into 1st!!! Before this happened the gearbox was fine, changed gear nice n smooth, no problems what so ever.
Once I got home I checked the linkage at the gearbox & all looks as it should (though I’m not sure) but at the lever end underneath I did spot this…
kinda looks to me like the linkage has slipped out the rear bush & bearing (though I’m no expert & this could be how it’s supposed to look). I’m gonna try tomorrow & see if it will go back in at all, also gonna check all the engine mountings as there was a good clunking noise or two when it happend. The clutch was still working as it should so I don’t think it’s that. All in all I could have coped with the alt, electrics & radiator problem but if it turns out it’s the gearbox I’m screwed. This is the last straw.
To top it off I’m supposed to start a new job on the otherside of town on monday night, so I need to try n sort the van tomorrow.
I’m completely & utterly pissed off, after a crappy start to the year, this just about tops it all off. It could be time for a rag in the fuel tank n a lighter!!! :axe
Yayyy! Result!!
