Flywheel question!
I need some advice…
I have a 1.6td Jx 1989 Caravelle.
How would i know if my flywheel was missing some teeth?
Crunching when starting?
If it is the flywheel…how on earth do i get to it to inspect it…
and probably more importantly how do i remove it and change it?
Engine out?gearbox?
Thanks in advance
James
Easy way to check is take the starter motor out and get someone to turn the engine manually. You can see the ring gear through the hole. If you need to change the flywheel you need to take the gearbox out
