fuel gauge
right guys lets see who can work this one out
full tank of petrol gauge reads 1/2 full and will drop to empty as the car uses the petrol.
i have changed gauge and regulator and getting same result.
i have changed sender same result.
i have manually moved floats on sender to full posistion same result
if you touch both wires together that should go on sender nothing happens
if you swap wires over on sender gauge reads full on one sender and nothing on the other sender
thats 2 gauges and 2 regulators and 2 senders all with same results more or less,
any one any ideas then
i thought that if you touched the wires together the gauge should read full
i would try rewiring it to see if that makes a difference feed and earth. if its still the same then just throw a match at it
:lol:
is that what you do in the cook
You are using a 1302 Tank unit? It has two floats and are they the right way round?
touching gauge wire to earth should show full tank
yip it does
Davey - 2006-07-26 11:06 PM
yip it does
Which means the gauge is working and the sender is to blame.
sorted now, i bent the sender
