Hi there,
I have a 1972 Convertable beetle. The soft-top roof is badly damaged and I’d love to get a new one made.
I’ve been to a coach fitters who have said what I actually have is a beetle with the roof cut off! The roof fitting is very odd, held on with press studs at the back. I have what I believe to be an original roof but it’s very badly damaged along with the frame (which turns out is incomplete and missing some brackets (to hold the frame on at the sides) as well as the screws at the front left and right on top of the windscreen).
Does anyone have anything similar that they could take photos of so I can see if I can get a metal engineer to replicate? Can try and send photos if it helps.
Thanks in advance, Christina
