Installing a clutch cable?
Does anyone have intructions on fitting a clutch cable to a late type 2?
What year are we talking? Bay window?
yes
77
depends if its broken or not. if its not broken or just the very ends broken tape some strong fishing line to the cable just behind the threaded end and pull through from front replace and atach line to new cable and pull through.
but if the cables broken or not there you have to remove the conduit which can be a pain then feed cable through then fit conduit then adjust cable
