Lowering polo 6n
Hi I’m thinking of lowering my 97 6n polo which is running on 15 inch polo gti alloys.
Not sure whether to get coilovers or just shortened springs? Not needing adjustability.
Where in Edinburgh could supply and fit?
Ta, mark.
Your best bet would be to just get the springs to lower it and not worry about coilovers unless you’re looking for a better quality shocker. If you get the springs yourself you’ll be more likely to find a garage to take it on as most mainstream garages usually only have access to standard parts readily available to them (from the likes of Dingbro, Pentland, etc).
Then it’s justa case of the garage changing the springs over for you B)
Kool. Any garages you’d recommend in Edinburgh? Preferably supply and fit.
Cheers , Mark.
Can’t recomend supply and fit but, try calling Marks Garage in Wallyford on 0131 665 1822. He’s a top bloke and should be able to sort you out…
