i broke up a mk2 polo 1.0ltr breadvan a while back but still have lots of bits left
1.0 radiater £10
fan shroud £7
full wireing loom inc fuse box,fuses and relays £15
front and rear wiper arms £2 each
door seals £4 each
interior door handles,winder handles etc from the doors £misc
window regulaters £10 each
front q-lights £5 each
ignition module and coil £15 for both
distributer with vacum £10
front seat belts £15 the pair
all engine mounts £10 each
starter £10
radiater fan £10
expansion bottle £6
ashtray and heater surround £8
clocks with 58k £10
clocks surround £5
heater controls from inside the dash £5
1 rear bulb holder £3
fuel tank (nearly new) £25
fuel tank sender unit floor cover £3
rear and front shocks covers(round plastic bits) £1 each
horn £2
horn push from middle of steering wheel £3
interior mirror £3
handbrake lever £7
4 speed gear linkeage £15
standard grille £10
exhaust manifold heat riser plate £5
water hoses £2 each
down pipe clamp £2
silver coupe tailgate £20 (collection only)
coupe bumpers,back complete,front missing inner bar(skin only) £15 the pair
a bag of tiny trim bits,bolts,rubber bits,plastic bits ask and i will check if its there
can post everything,what u needing!!!
