I found play in the nearside rear wheel bearing of my 1303 so I ordered a bearing kit. Fitted new bearings and seals only to find there was still play in the bearings. Could there be wear on the stub shaft? the play seems to be in the outer roller bearing only.
You are allowed a little play in a bearing. As long as it’s not excessive.
