Rear seat belts
I currently have 3 lap belts in the rear and wondered how easy or otherwise it is to convert those to 3 point seat belts - anyone got any experience of this?
Julie
If you don’t have cupboards you can fit two 3 point belts not sure about the third.
I got my kit from http://www.brickwerks.co.uk/
Kev
Julie. The bays came with either no mounting points or mounting points for three point belts. If yours has factory mounts then you will see the mounting points just below the rear side window. It might be covered. If you need to fit them then it is a bit of a hassle but can be done. You would need to weld a couple of plates in. Give me a bell if you want more info. 07989 163 138
As a rule of thumb. Panel vans dont have mounts, and factory windowed vans do :thumb:
