Speedo light
With darker nights and now using lights sometimes, I see that the light behind the speedo has gone. Indicator light is on but no high beam or heated rear window light - fuse or bulb? If bulb - easy job?
bigjock2 - 2007-08-17 6:04 PM
Firstly speedo light, try twisting the light switch, on most models it acts as a dimmer for the speedo light. If this does nothing, got to back of speedo and locate the correct wire and earth it out using a test bulb (with lights switched on), if it lights up you have power and the bulb is knackered. to remove pull bulb holder out of back of speedo. Try to avoid pulling via the wire or its terminal or you may break the holder. Replace with new bulb and refit. Use the same process for the other bulbs. Jobs a good un! Bugs are easy to work on.
Thanks Keith! :smiley: :smiley: :smiley:
