Hi people, anyone have a steering wheel puller that will work on a 66 bus, my wheel is well and truly stuck. I have used wd40, a make shift puller plus I have tried the wobble technique and not seeing any movement. Any help would be really appreciated as I can’t move the bus since there is no rear end and I have been waiting for two years for my brakes from creative engineering.
Ok so no need for a puller any more, top tip people use a blow torch to heat the top (small kitchen one works best gives you more control) and pull directly up gentle. Believe it or not this worked in less than five minutes. Have seen the hot water method but frankly that seems crazy to me, so peeps go with the blow torch. Peace…
Oh by the way if anyone wants my old steering wheel its yours for the price of 10 Benson and hedges. I have no use for it, not in the best condition but look aren’t everything. Its a black OG one with a few small cracks and chips…
Hi ollie, if you’ve still got the wheel, i’ve got 10 B&H with your name on them heehaw.gif My wheel is Knackered
