T4 Caravelle Alloys with Tyres
Hi there,
I’ve got a set of original T4 Caravelle alloys with load rated tyres in good condition (a few wee scrapes and a touch of lacquer peel). The tyres still have plenty of wear on them.
I’m looking for £280 for them - Give me a shout if you’re interested
any ideas if they will fit a T25 ?
Hi there
I think they probably will, you will have to buy a kit to extend the studs and maybe a set of spacer.
Hope this helps
OK but I would need to be sure - where are you abouts ? What is the diameter of the centre hole ?
Kilmarnock, ill check size tonight
Sorry for the delay in getting back to you. Just measured the diameter, its 63mm/2.5".
Hope this helps.
Alas I think the minimum centre bore to fit a T25 is 66mm
Never mind,although a freind of mine had the centers taken out a bit at a local metal shop. I think it cost him a tenner,fronts should fit staight on.
Mabe that helps
you got a phone number ?
07745143389
Folks
£220 to clear, also have a set of 17" 5 spoke alloys original Audi would look great on a t4 to ! Two of them needing tyres replaced £170
